LeetleGreyCells
Un rouleur infatigable
- Whitehaven Mansions
Yumezi
Those routes are all pretty short and flat, aren’t they!
Hope there’s something longer and more challenging at the top/bottom out of scrolling view!
Bit concerning that all my best times for the london hills seem to be from 2018/19 🤔And look at Tommy here:
1,029m of elevation that is.I will share this with all of you while I am thinking about it - the profile for Tuesday's final stage:
Note that Box Hill is NOT eligible for Prime points - because you approach it from the Richmond Park direction, you don't go through the start timer by the roundabout. Also note that for Leith Hill (and to a smaller extent Fox and Keith), it's only the timed section that I've marked in pink that counts for fastest climb times, not any of the lead-in.
👀1,029m of elevation that is.
Alpe Du Zwift is 1,036.
Just saying....
Crikey. I think my best time up AdZ is a little under the hour and I’m nowhere near that. Then add in the descents, this could be over 90 minutes on Tuesday!1,029m of elevation that is.
Just saying....
Well the Strava KOM for that course is 1:03 and the QOM is 1:12.....so yeah, don't make any other plans for Tuesday eveningCrikey. I think my best time up AdZ is a little under the hour and I’m nowhere near that. Then add in the descents, this could be over 90 minutes on Tuesday!
https://www.strava.com/activities/5048860933Crikey. I think my best time up AdZ is a little under the hour and I’m nowhere near that. Then add in the descents, this could be over 90 minutes on Tuesday!
