Any thoughts on the course Al? As what we're planning to do is essentially a Hare & Hounds style race (as I understand it?) is it worth copying the H&H route this week to get an idea of suitable time gaps between the categories - I appreciate we may have to tweak these slightly for our own use but it should at least give an indication of suitable time gaps?
For example, this weeks's H&H is Watopia Flat and they have D off first, with C starting 7 minutes later, B are at + 10 minutes (so 3 mins after C) and A are + 12 minutes (2 mins after B).
It's arrived!
I'll give a full report when I have a play. Hopefully this evening (although it's roasting in the garage so will just be a test run).
It's arrived!
Mine is due today too .... like you will give it a try when it gets hereIt's arrived!
Yep - 6 screws on the bottom. Picture below attached of the innards for your curiosity @CXRAndyDoes the bottom come off with screws?
Are those bumps at each end of the arc just end stops?
Interested to see what's inside![]()
Doesn't seem much for £70 when you look at it that way does it?!Yep - 6 screws on the bottom. Picture below attached of the innards for your curiosity @CXRAndy- just a tiny pcb and a angle sensor basically.
Also yep - the bumps are just soft end stops at the extremities of the arc.
Could've chucked on a couple of LEDs for show surely? I suppose that's the beauty of exclusivity, you can charge what you like.Doesn't seem much for £70 when you look at it that way does it?!
I'm waiting for @CXRAndy 's guide to making a DIY versionCould've chucked on a couple of LEDs for show surely? I suppose that's the beauty of exclusivity, you can charge what you like.
That said if it works as well as the reviews say it's a good piece of kit
Well done
PS I used to live in Downend (Bromley Heath)
My dumb sterzo has those bumps and they are just end stops.Does the bottom come off with screws?
