I don't like that you have to use your real weight and height with trainer reality set to 100% ...I don't like the 2020 updates tbh. The pandemic patch has made things much worse
I always ride central these days. At least 3ft but more like 5ft from left kerb. Personally I've had much less trouble from drivers by doing this.
Where was that last week. I was out in up to 38C at times with 50-70% humidity. Even the water from the cold taps was warmI went for a ride yesterday evening, leaving in 32 degrees of heat. On the way back I was caught in a really heavy thunderstorm. It was beautiful, cooled me down and had me smiling the rest of the way home. Only issue was the rivers of flash water running down the side of the road forcing me out towards the middle of the road.
Results so far - 17 voters which seems to capture most of the currently active group members ...Numbers do seem slightly thin on the ground at the moment. Can’t think why!
@Alongo, @Marino.g, @Milzy, @Norry1, @CXRAndy @peterob @anyone else I can’t think of right now. Fancy it?
It is going to be a fair bit cooler next week so maybe that’ll persuade people. Maybe...
Also we promised the next one would be flatter than the last couple if that sways people’s mind![]()
I voted for both but thought the vote showed who was voting to the surveyor , didn’t realise it was anonymous .Results so far - 17 voters which seems to capture most of the currently active group members ...
RESULTS
In summary - very close ...
Tuesday 11 ayes
Wednesday 12 ayes
so on that basis I’ll create a meet up for next Wednesday 👍
RESULTS
Tuesday 11 ayes
Wednesday 12 ayes
RESULTS
Tuesday 11 ayes
Wednesday 12 ayes
Flippin 'eck, that were hot! I lost the best part of 2kg and that was even with having the air-con unit in the room with meSigned up to a race at 18:00 tonight ... could be a big mistake in this heat!![]()
Yer I had a race tonight aswell. Blooming warm and I had an air con unit aswell. Think that was working harder than me 😂. Think I’m getting the hang of the bike a bit more now. Put my concern about the delay on the stages fb page and few have said it’s known on ant+ and is being addressed in next update. Tried on Bluetooth as suggested and felt loads better. Tactically my best race in B cat tonight aswell first top 10 finish (only 16 on zpower 😂) but only 1min behind winner and stayed with 2nd group till the end on 36km so we’ll happy with that.
Glad you're liking the bike - and doing well in racesDefinitely helped you loads to race in B.
I couldn't get ant+ to work properly with FulGaz so bought a Bluetooth USB stick (couldn't get BT working very well on W10 directly) and now use that all the time even on Zwift. Works perfectly. This is the one I have - cheap as chips. Worth a try?
Amazon product ASIN B07PPV29CYView: https://www.amazon.co.uk/gp/product/B07PPV29CY/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Any thoughts on the course Al? As what we're planning to do is essentially a Hare & Hounds style race (as I understand it?) is it worth copying the H&H route this week to get an idea of suitable time gaps between the categories - I appreciate we may have to tweak these slightly for our own use but it should at least give an indication of suitable time gaps?Results so far - 17 voters which seems to capture most of the currently active group members ...
RESULTS
Tuesday 11 ayes
Wednesday 12 ayes
