I just use multi-purpose lithium grease. You can get a big tub of it at Wilko. It costs peanuts. About £5 for 1/2 kg. For most people that would last about 10 years.
) so might just bite the bullet and bother the LBS..Copper grease. A small tub will last decades
Eg
Anti Seize Copper Grease For Bikes Cycles Cars High Temperature Assembly Lubricant 30g https://amzn.eu/d/iP2qlWZ
Eg
For decades I used the tin of grease on the garage shelf that went in car grease nipples back in the days when they had them, then when I got into cycle touring I bought a small tube of the white lithium grease for no particular reason other than it seemed to be the stuff to have. When I got to opening up the stuff I'd put it in, I found that all the volatile compounds had evaporated off, and all that was left was a chalky dry residue, and a PITA to remove it.
Since then I've used some red stuff in a tube I picked up in Halfords cycle dept.
The original stuff I was using is Castrol LM, which is a lithium grease, but it's pale brown, not white, and it doesn't dry out.
When I was growing up my dad had a tin of grease that had a circle of metal resting on the top with a hole in it, as did the bike shop. Press on the circle and grease came out of the hole while the disk slid slowly down the inside of the tin. Castrol I think. Never seemed to run out. Got some Weldtite lithium stuff in the shed now though lol
