I just started on the diet/training.First 2 weeks I lost 14 lbs,and was well chuffed.Just weighed myself tonight and this week only lost 1lb !
Eating well,no different to previous 2 weeks so I guess im building up muscle with the cycling,which is getting easier
Maybe I just need to go up a level with the cycling?
If you lost 14 lbs in 2 weeks, something is wrong! Thats not sustainable, 7lbs a week is ridiculous weight loss, have you been weighing yourself at the same time of day, i.e. preferably in the morning, naked after going to the toilet? Even if you are a big guy you shouldnt be dropping 7lbs in a week. Which you have probly come to realise since you can only just shift 1lb a week (which is a normal amount of weightloss, 1-2lbs is acceptable). Unless you are pretty much in trim then muscle gain should hardly dent weight loss figures, muscle takes longer to build than fat does to burn.
To put this in context, I've been cycling and running about 5 months seriously, lost over 2 stone, and my muscle mass has hardly increased at all (definintion has obviously improved, but actual measurements of thigh size etc, actually have decreased slightly due to fat loss), yet I'm a pretty strong cyclist for a non-racing type.
Maybe Jimbo can be arsed to explain the numbers for you here since he seems to enjoy doing that, sadly I really cant be bothered because there are so many guides, studies, books etc out there already, you need to do some reading though by the sounds of it.
Good Luck with your weight loss.
