Cletus Van Damme
Previously known as Cheesney Hawks
- Out in the sticks...
I fitted a MTB cassette with a 34 tooth bottom cog, but it was because I had a compact chainset rather than a triple, I also needed a mtb derailleur and a new chain. If I had a triple chainset I would get the smallest granny ring I could (24 tooth?) and use it as a double chainset plus a granny, rather than a triple
Is the front mech fine if a really small inner chain ring is used? I also wondered if my existing rear mech would be able to take up the extra chain length that a smaller inner chain ring causes. Is this what a long cage rear mech is for, or is it for clearing the larger sprockets on a 11-32 cassette for example or both?
If you measure the distance between chain ring bolts and they the same on both bikes, then I can't see why not.
If you only need it as a 'bail out' option then it could be worth going for a 26t as a 28t might not give you a much lower gear as you have now.
I think the downside would be slightly rougher changes between middle and granny ring, but you wouldn't need a longer chain like you would if you go for a bigger cassette![]()
Potsy as I mentioned in my reply to Alun's post do you think that the existing Tiagra rear mech would be able to take up the slack from 26t chain ring, or is it just trial and error. Thanks again.
