Are you still using the OEM blocks?
Indeed I am.
yes, if they lock they clearly work, but it's hard to find that 'sweet spot'. It's make sense that it's the wheels because it means the grip on the brakes is outweighing the grip on the tyres. so new tyres it is then. thank you
and mrandmrspoves, i'll look into that, too thank you.
looking into tyres at the moment. also, quick question, when releasing a rear wheel, do the gears stay in place? or do they fall? not got the confidence yet to put them back on. thanks![]()
Everything other than the wheel stays in place! Do it like a pro though! Small ring at the front, small cog at the back, release the brake and the QR skewer and lift the bike up (you might have to pull the rear mech back a tad) and the wheel will drop out. Now manouvre the frame so the chain clears the wheel axle and take the wheel out of the way! Then get your team mechanic to pass you a replacement wheel and put it in the opposite way you took it out! Do not turn the bike upside down!
legends! both of you! everyone here fills you with confidenceWhen you take the rear wheel off the derailleur stays in place - you just have to pull the chain away from the rear sprocket once the wheel is released.
And when it all goes back, remember to reset the brake.
I forgot once![]()
You mean you didn't give the wheel a spin, check the brakes were working and then give yourself a thumb's up while telling your girlfriend/wife/boyfriend/husband/pet cat, that's how it's done?
Why not turn the bike upside down, i have always done that even on my T3, be interesting to know why, can doing it damage it or do anything else, i do find the T3 is a bit of a pain like the skewer nut catches on the derailier, took it of today so i just unscrewed the nut off.Everything other than the wheel stays in place! Do it like a pro though! Small ring at the front, small cog at the back, release the brake and the QR skewer and lift the bike up (you might have to pull the rear mech back a tad) and the wheel will drop out. Now manouvre the frame so the chain clears the wheel axle and take the wheel out of the way! Then get your team mechanic to pass you a replacement wheel and put it in the opposite way you took it out! Do not turn the bike upside down!
