Yellow Saddle
- Loch side.
So his assumption in his modeling was wrong and he needs to go back and redo it. The conclusion will be the same but not for the reason he thinks.
Who is he and what was his assumption?
Sorry, at first the diagram in question post didn't show so I assumed you referred to the author of the paper and the last drawing in the thread.Well look at my post you replied to, I quoted the persons post it is all there and he assumes the bottom three spokes are supported differently to all the others.
From what I can see, he (@Salar) made no assumptions which were either proven right or wrong. I think the "support means contact or at the very least, within the LAZ. I'll let him comment on his own drawing.
But, I'll stick with the answer that the bottom spokes don't need support to stay upright or straight since they are in tension.
"The tests were carried out while the writers were employed at Imperial College (assume London)" ( last paragraph). Stepping on and off the Engineering Department's pater-noster lift was the highlight of my attendance at structures lectures bitd.From the very engineering department where I mostly snoozed through structures lectures!
I know you won't mind if I say that I differ. I maintain that saying that the load "stands on the bottom spokes" is misuse of the word 'stands', is therefore not correct terminology. Saying that the load 'hangs' on the upper spokes is false too - ie a misuse of the word 'hangs' and use of either terminology does not help to understand how a wheel supports a load.I still maintain that the correct terminology is to say the load stands on the bottom spokes. The fact that the mechanism is reversed doesn't matter,
What I meant was that it seems to be readily accepted that, in an actual wheel that you could use on a bike...Not really, there wasn't any consent here, if any, until just a few months ago. It wasn't just the nomenclature, it was the concept.
Replying to the posts you made yesterday evening.[Ajax Bay]: "For me E=W"
Why?
It is clearly possible from a statics perspective for the change in tension to be entirely in the upper spokes.
It's only deformation in the system which defines where the load is taken.
Thinking about the two spoke system, for simplicity, if all the change in tension were in the lower spoke, it would reduce in length. The upper spoke would then increase in length and would therefore increase in tension as a result.
So I think it's not possible to have the entire change in load either on the upper, or on the lower spokes. It must be shared.
The two-spoke system may be simple, but it's not a wheel (you couldn't put it on a bike and ride), so there's no point thinking about itThinking about the two spoke system, for simplicity,
The rim is defined as rigid so perhaps you could. Fair bit of tension in the two spokes when they went through horizontal, mind. If the spokes could take compression then perhaps a three or four spoke wheel would roll OK.The two-spoke system may be simple, but it's not a wheel (you couldn't put it on a bike and ride), so there's no point thinking about it
Are you suggesting that the spokes of properly (?and regularly) stress relieved wheels do not fatigue and finally part?the OPs spokes keep breaking because they are fatigued
The root of the problem is that the wheel wasn't stress relieved after being built
Have you ever actually managed to break a spoke during "a good hard stress relief session" (you could give the wheel a good hard stress relief session, replace the spokes that this broke (no loss, they would have broken soon anyway),
)?There is no point in regularly stress-relieving a spoke. Stress relief is done once, after finishing building the wheel, to normalise internal stress in the spoke which derived from the bending, stamping and threading steps in manufacture. Stress relieving later on in the wheel's life is useless.Are you suggesting that the spokes of properly (?and regularly) stress relieved wheels do not fatigue and finally part?
Have you ever actually managed to break a spoke during "a good hard stress relief session" ()?
I see Jobst Brandt said he'd done this:
"My first experience with this [squeezing spokes to achieve much higher tension levels temporarily] was years ago when I had frequent spoke failures and wanted to be done with it by attempting to break any spoke that was about to break. That is where I stumbled onto stress relieving. I broke two more spokes by forcefully stress relieving the
wheel and then there were none for a long time."
