rogerzilla
The left hand spokes can't always* be tightened enough to prevent them going completely slack when you hit a bump; the lowest one may be perilously close to zero tension when just riding along, if you're fairly heavy and the rim can't take a very high average tension. The RH spokes are prone to mauling from an unshipped chain but otherwise have a better chance, since they never get anywhere near slack and the variation in tension when riding, as a proportion of initial load, is much smaller. Spokes don't break because they are too tight. The difference between leading and trailing spokes isn't massively important on a wheel with a rim brake, and builders can never agree on which side of the flange they should go (I like the "pulling" spokes to be heads-in, since they're better-braced, but some people insist they should be heads-out to pull the spokes clear of the rear mech cage on climbs!).
Derailleur wheels are a horrible compromise, really. A dishless wheel, such as you get on a fixie, singlespeed and on some IGH hubs, gives far less trouble but you just can't have one with 11 speeds (or even 7) and the usual 130mm spacing. That spacing can't be increased much further because your feet end up too far apart at the pedals.
*DT Revolution or other thinner, stretchier, spokes, are good on the LH side because they are more able to retain tension under a big shock load; they stretch by 0.5-1mm when tensioned.
Spokes are drawn and therefore much stronger than plain stainless material. A Sapim Race spoke has a strength (they don't say what, but it's usually yield strength, not UTS which is even higher) of 1300 N/mm^2. So my 150kgf spokes aren't anywhere near that, at about 580N/mm^2.A spoke (say plain gauge 2mm diameter) has a cross section of 'Pi'mm2. It's under tension of (say) 1000N so about 318N/mm2. "A simple rule of thumb calculation for the fatigue limit is one-half of the ultimate tensile strength " which for stainless steel (material of spokes) seems to be in the region of 500N/mm2. Half that is 250N/mm2. So properly tensioned spokes are above the fatigue limit of their material.
