Heltor Chasca
Out-riding the Black Dog
@Pat "5mph" I wouldn’t pay attention to many of the suggestions upthread.
What you need is a diving bell.
*groan*@Pat "5mph" I wouldn’t pay attention to many of the suggestions upthread.
I too have this problem on my Genesis@andrew_s
It does not fit the handlebar of my Genesis
*groan*
"But even so, some bell properties might influence:
- Steel is denser than aluminum, so a similar-sized steel bell should have more mass and ring longer;
Bigger rings might also ring longer because of the relation among size mass, wall-thickness, and frequency pitch.
Try mounting the bell at an angle on the handlebars. You'll end up with only one part of the bell lower than the rest, with a minimal surface area for the water to adhere to without gravity coming to your aid.
Or better still, modify a cocktail umbrella using clear varnish to make it waterproof and mount it over the bell to protect it from the elements.
The bell would get wet underneath? Same results?
6 and half a dozen here!
My most effective ever "get out of the way" audible warning was a carefully cultivated rear brake, that would squeal very loudly whilst providing a minimum amount of retardation. The cultivation consisted of the occasional oily fingerprint, and the pedestrians (in Cambridge) were mostly those who stepped off the pavement to pass another pedestrian, with their backs to the traffic. They certainly got back on the pavement pretty sharpish.Horns are great if used occasionally on a wired up, oblivious pedestrian, or during critical mass .... I fear they are not polite though
Yes, I've got one, and it works really well. It's loud. Do you want it?
.......p.s. you haven't invoiced me yet
Glad it arrived OK, and yeah, it isn't pristine. Mainly from kicking around various bike sheds for the last 20+ years.
Less than £3. It isn't worth generating the paperwork.
