Where is
classic33
Leg End Member
Sod off, I'm still on prisoners. Its to do with switch combinations, but I cant figure out what exactly.
You asked for it!
Moon bunny
Judging your grammar
Appoint 1 counter the others are "flippers"
When a flipper visits the room if switch 1 is on flip switch 2
if switch 1 is off and the flipper has seen it on previously, and never flipped it on a previous visit, flip it on, otherwise flip switch 2
If 1 is off and he has previously flipped 1, flip 2.
Counter:
If 1 is off flip it on,
if 1 is on flip it off, if he did not flip it on on his last visit, increase the count of prisoners who have visited the room by 1.
R
Risex4
Dropped by the autobus
Counter:
I was getting hung up on the unknown starting position of switch 1 and the visits of flippers being outside of control before the first visit of the counter.
nickyboy
Norven Mankey
At noon the hour, minute, and second hands coincide. In about one hour and five minutes the minute and hour hands will coincide again.
What is the exact time (to the millisecond) when this occurs, and what angle will they form with the second hand?
(Assume that the clock hands move continuously.)
As the hour and minute hands cross 11 times in any 12 hour period, the time between the crossings is 12 hours/11
So the first crossing that you ask for is 12.00 (Noon) + 12hours/11 = 1hr 5minutes 27.2727r seconds
The prison question is puzzling me. Given the prisoners are chosen at random, there is nothing to prevent an infinite series of the same prisoner being chosen. Or have I misunderstood?
classic33
Leg End Member
But at what time does it happen?
Correct with nothing to prevent an infinite series of the same prisoner being chosen. However all must flip one of the two switches at least once.
nickyboy
Norven Mankey
13.05.272727272727r
And I give in on the prisoner question. I can't make the logic step beyond the scenario of an infinite series which would seem to prevent all the prisoners being chosen at least once. Maybe I need more coffee
Edit: forgot to give the angle. 130.90909r degrees
Pale Rider
There's a solution online which relies on the appointment of a counter.
However, it also relies on the counter being regularly selected to go into the switch room.
If I read the problem correctly, a single prisoner - in this case the counter - could be selected to go into the switch room once, but never again.
If that's right, the solution doesn't work.
Make like a turkey at Christmas..
Here's a picture of Turkey at Christmas.
This tree is made of Istanbul's
