When were cable operated brakes first used on mass produced bicycles?
Hope this is the right forum for the question.
I've seen them on adverts for sportier mid 1930s models.
Sharky
Kent
Just googled some early Tour de France pictures and they seem to be cables by 1923, so probably being made well before then.
Cycleops
Accra, Ghana
From the net:
The invention of the Bowden cable has been popularly attributed to Sir Frank Bowden, founder and owner of the Raleigh Bicycle Company who, circa 1902, was reputed to have started replacing the rigid rods used for brakes with a flexible wound cable but no evidence for this exists.
Although rigid ' rod' brakes were still being used up until the sixties and possibly later.
tyred
Ireland
From the net:
I think that Raleigh had a rod-braked model listed in their catalogue as recently as 1985.
raleighnut
From the net:
Yep falsely although Raleigh did aquire the patent from the inventer
The invention of the Bowden cable has been popularly attributed to Sir Frank Bowden, founder and owner of the Raleigh Bicycle Company who, circa 1902, was reputed to have started replacing the rigid rods used for brakes with a flexible wound cable but no evidence for this exists. The Bowden mechanism was invented by Irishman Ernest Monnington Bowden (1860 to April 3, 1904[2]) of 35 Bedford Place, London, W.C.[2] The first patent was granted in 1896 (English Patent 25,325 and U.S. Pat. No. 609,570),[3] and the invention was reported in the Automotor Journal of 1897 where Bowden's address was given as 9 Fopstone Rd, Earls Court.[4] The two Bowdens are not known to be closely related.[5
Ming the Merciless
There is no mercy
Inside my skull
From the net:
I had a bike with solid tyres and rod brakes as kid in the 70s
FrothNinja
FrothNinja
"The Bowden Mechanism was not developed in connection with a cycle brake as there is no record of the cable having been associated with the cycle industry until 1902, when George Larkin's invention was patented. During Larkin's employment with Bassett Motor Syndicate his duties included the assembly of motor cars and motor cycles, and a major difficulty was the assembly of the braking systems which at that time comprised steel rods, not easily adaptable to the contour of the chassis. He designed a flexible cable brake and approached S.J. Withers, Patent Agent, to have the design patented. Withers noticed the similarity of Larkin's idea to the Bowden Mechanism and introduced him to the Bowden Syndicate, who agreed to manufacture and market the invention with the proviso that it should be patented jointly in the names of the inventor and themselves." (National Archives, National Motor Museum, George Larkin Collection)
Thanks to clues above I now know the patent date for cable operated brakes. When they began to be used on mass produced bikes remains a mystery though I suspect it must be post WWI. It seems that most early mass produced rims did not have sufficient side wall for side pull brakes to produce enough friction/resistance to work efficiently so the rod brakes were a safer option in most cases.
The mystery remains....though 20s/30s seems likely.
FrothNinja
FrothNinja
On my 1936 Hercules (an FA I think), I suspect they are the originals, though the actual levers may be later.
