gbb
- Peterborough
Even with 10 speed, I'd get 1200 to 1600 miles put of a chain. My 10 speed Veloce equipped bike is on its third chain with the same cassette and as yet shows no problems. With an 8speed, you should easily do the same if your chain is changed in good time.On my current chain and cassette, I have done 1000 miles. I cycle regularly meaning I'd need to change both around 6 times per year.
Luckily I don't need to buy expensive components as my bike is 8 speed. Right now both chain and cassette cost together £30. £180 per year assuming Id need to change it 6 times per year every 1000 miles.
And if my bike was an 11 speed these costs would be much higher!
I am fairly new to cycling but these expenses are not very pleasant.
I would not mind replacing the chain by itself every 1000 miles.
But from all the comments I see, needing to replace both is just too expensive considering the costs.
I might need to reconsider cycling as a hobby
Cost of an 8speed chain is what?, a tenner maybe...nothing to think about IMO, just replace the chain, it's cheap, it's a no brainer. Only worry about the cassette if you put a new chain on and have problems.
