See Musa!!! I knew you would ruin this for me............Lol wtf going on never realised I was LBS
Check out www.ridemybikes-eatmyfood-liveatmyexpence.com for holiday experiences.
What could have been.
mind you I'm also coming up your neck of the woods this year (Fort William) and bringing bikes if you wanna catch up
The issue is usually long descents on carbon rims. Some suggest that clinchers are the worst offenders due to their u shape profile.Out of interest, had anyone any experiences to share on the different braking performances of carbon vs alloy rims?Wet and dry conditions? I've always shied away from carbon rims due to perceived poor braking.
Also, basalt braking surface? What's the difference?
all your bikes are small unfortunatelyLol .. seriously if you fancy coming up to London I would be happy to show you round and loan you a bike
I think what you really need is a holiday in Perthshire, Scotland. It's the holiday destination of the year. I could even recommend a few hotels. Hell i'd even let you put your bikes in my storage facility.Lol .. seriously if you fancy coming up to London I would be happy to show you round and loan you a bike
Carbon rims don't brake too well in the wet - or at least the ones I have don't. If it's wet I will usually switch to wheels with an aluminium brake track...
If you are doing a long descent on a carbon rim then you are on the wrong wheels.
Just talking from experience, haven't tried the new Firecrests and maybe they are matched well with their own brake blocks, but still can't believe they are as positive as alloy rims. Then again I could be wrong, I frequently amWhy do you believe this is, when climbing and descending I would pick Zipp full carbon firecrests over anything in dry weather, I find that they do not suffer as much with brake fade on long descents as the Carbon fails to retain heat as much as alloy breaking surfaces.
I run full carbon firecrest wheels with carbon braking surfaces every day and have not experienced any 'grab' from them myself.
.Many of the peloton ride full carbon rims over large climbs and descents. I think, if used correctly, they are fine. Ridden hard down long descents everyday though and you would likely find the wheels durability will be shorter. Pro's just swap out for new after each race but then the amateur would not likely be riding 10k descents daily.If you are doing a long descent on a carbon rim then you are on the wrong wheels. In the wet also nowhere near the performance of an alloy rim even with the special brake blocks, then when they dry out they can "grab" and be a bit unpredictable. The only time we use tubs with all carbon wheels is on TT's and I think that is a general practice now.
