andytheflyer
- South Cheshire
There's a much quicker, simpler and more accurate way to eliminate spoke torsion than doing it by feel as the books recommend.
After you have laced the wheel, and before you start tensioning, go around with a dvd marker pen and mark the end of each of the spokes next to the nipple. It only takes a couple of minutes, but once it's done you can remove the torsion by sight instead of feel. Not only is it a more accurate way to remove torsion, but you can accurately see how much adjustment you're making to the spokes as you true the wheel too.
There's a paradox with building wheels. The more you enjoy it the better you're likely to be at it, and the better you are at it the less often you'll have to do it.
Ah - so as you tension up a nipple, you can see if it's twisting the spoke - much simpler than RM's tape flags method. Neat idea. Thx.
