Whats wrong with our shower?
sounds like you need to calm down and have a cold shower..... :okay:
oh VERY FUNNY !!!
ANYWAY: I have found a utube thingy of a similar unit [back off] showing how to do simple ohms/continuity tests* on the main components; that may well diagnose a part (e.g. heating filament(s) ), and some SHOULD be available from the Mira site linked above [thanks!].
There is hope ... of a better shower in my future :P
*it will probably take me longer to get it off the wall than to do the tests ... Does a real man bother taking out fuses for such tasks?
Nah - water and electricity - what could possible go wrong
in other words - yup
sleuthey
This may be a bit simplistic
but an electric shower always has to have a main cutoff switch on a pull cord or just outside the bathroom
It hasn;t accidentally got knocked off has it?
or the fuse blown/contact breaker tripped?
best to start with the simple
sorry if this seem over simple - but I used to work in IT - the number of computers I have switched on in nobodies business!
This ^^^
Beebo
Firm and Fruity
Hexleybeef
Mira are great at after care.
My parents have a 20+ year old Mira. Still has parts and can still be serviced.
We bought a Mira shower off the back of their recommendation.
Lookrider
oh VERY FUNNY !!!
If you upgrade your shower in future ...you "may" need a larger supply cable ( 6mm or 9mm2)
Depending on the voltage supply of the new unit
Also length of cable run can have an impact on voltage drop ( all be it very small ) the new shower will have minimum size supply cable rated on the back of box
Nothings ever straight frd is it ( sorry)
Randomnerd
Bimbleur
North Yorkshire
Thermostat furred up, maybe.
If you've the model number and a pic then someone like showerdoctor (I think Edinburgh based) will send you the part.
Switch off the mains first.
The bloody thing came back to life almost as soon as I stopped reading your replies, folks!
I'm gonna suspect a loose contact in one of the sensors or heating switchery - it's probably on borrowed time, but no point trying to diagnose a ghost fault so we'll just crack on using it for now :smile:
T4tomo
Ahhhhhhh.....So the Mrs had turned it off on the pull cord but you don't want to lose face by admitting it? :laugh:
Reminds me of a computer system I used to be the backup support for
I knew naff all about it
Support notes from my team leader (who did know about it) said
"talk to John Berry (a computer operator on site - we were 2 hours drive away!) about it and woffle until he figures out something that appears to have worked - then tell me about it when I get back from holiday"
He didn;t do documentation!!!
basically fiddle with something until it works then leave well alone!
Fab Foodie
Kirton, Devon.
Ah, so possibly low water pressure then :whistle:
Sometimes it takes very little visible change to be the wrong side of the trigger pressure.....
presta
Careful you don't end up with a fire. I had a loose connection in my old shower, but it wasn't noticeable until it started melting the case.
