What's been a backwards step in technology for you?
SpokeyDokey
Done that.
Ok thanks. :okay:
They are so bad that it was probably worth doing again. ^_^
Loathe the damned things.
ColinJ
Puzzle game procrastinator!
Not just that the shifting is far quicker, slicker and precise on the bar ends .
You must have had either very crappy, or badly adjusted kit... :whistle:
My Ergopower controls are Click (lever)-clunk (chain)-click-clunk-click-clunk; no hesitation, no missing, straight in there!
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Even when working with DC you have to move the levers far further than bar end to initiate a change. Bar ends are simply faster, slicker, and spot on.
ColinJ
I spend most of my time riding with my hands on the hoods, so a movement of one finger or thumb is all that is needed. To use bar-end shifters or (*shudder*) down-tube shifters would require arm, hand and finger movements every time!
Anyway, I'm glad that you are happy to be in a small minority of retro-shifting cyclists! :okay:
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
If you can shift the lever through the required travel for a gear shift with just your thumb you clearly don’t have D.C. like the Shimano offering I had.
Profpointy
Dual control brake / gear levers. They are shoot. Went back to down tube / bar end shifters and brakes that just do braking.
The modern version "cross stops" (I think?) are very good indeed, so in this case the new tech is a vast improvement
ColinJ
I use Campagnolo Ergopower on the bike in question. The change from bigger sprockets/rings to smaller uses a thumb movement on a small lever on the inner edge of the shifter. An inner lever shifts the other way and changing by one gear is a short click on the lever. Multiple single clicks or one longer movement can be used to shift multiple gears in either direction.
I have Shimano Tiagra on my CX bike and I don't like the STI action as much as Ergopower's method, but I still prefer it to the down-tube shifters that I used 30+ years ago!
