Ming the Merciless
There is no mercy
- Inside my skull
That’s really warm, 23C! Someone didn’t read the note.
We had a new boiler last November, it came with one of those fancy Google Thermostats, which is very good you can place it where you want in the house, it's currently in the living room set at 19 deg for getting up and evening periods I between it's at 9, depending on room temp it switches on the heating at different times to achieve the setting temp at the set time.
MrsPete is prone to upping it into the low 20's sometimes but I soon drop it back down again 😂
I used to take the plug off the electric fire when I went out to work to stop the wife using it (hmm i wonder it that had anything to do with why she run off with the milkman) 🤣🤔Get a sticker overlay that claims 22C, when really it’s 17C…
i believe that's a TRV (thermostatic radiator valve), so it should heat up radiators only when necessary , again, i believeI don't set mine because I don't know how to set mine, plus I don't know If I have one or where it is If I do have one, but if I did have one I'd have it as high as possible. I do have my central heating on as high as possible, controlled by these things.
I voted.... 27/ 🔥Votes: 12.0% by the way
We set the Hall thermostat to maximum and have TRV's in on every radiator - these we adjust as necessary.
I thought that there has to be one that doesn't have a TRV?So what stops the boiler if all the radiators are set below the max on the thermostat, wont the boiler keep running ? or am I missing something here.
