What Shifters Are Best For Converting From Down Tube Shifters? Reynolds 1983 531 Double Butted
bigjim
Manchester. UK
I did find 8 spd was the max for non-indexed DT shifters.
I use DT shifters on one of my bikes with a 9 speed cassette. It works fine but you do need to have a sensitive touch with it as its easier to hit the wrong gear because of the very narrow spacing between cogs.
Surely if you do not spread the rear triangle you are limited to a freewheel axle that is more subject to breakage due to the drive side bearings being under more strain than the newer Shimano cassette design?
Sterba
London W3
If Coppi and Bahamontes managed in the Alps with freewheels, I don't think we mortals have anything to worry about. I have never had a moment's trouble with a freewheel. The main problem now is the difficulty of getting the exact cogs you want.
