What needs changing on bikes?
ExBrit
Red light sensors that automatically apply the brakes. It'd be popular with Mail readers if no one else.
I'd prefer red light sensors that can detect cyclists instead of ignoring them.
lazybloke
Chocolate eclairs: the peak of human endeavour
Leafy Surrey
Put them on cars too (operational all the time).
And just to add to the bottom bracket argument, cotter pins and square taper were rubbish if you wanted to take bits off (eg to clean chainrings properly or to clean the frame behind).
HT2 makes that a trivial task, is compatible with old frames, and I've yet to see any longevity problems
Ming the Merciless
There is no mercy
Inside my skull
It's called a Huffy
One I’d like to ride
personally I would love some sun glasses that fit over normal glasses but don't look dorky
Oh - and a lightweight battery for ebikes that hold loads of charge and recharges in 10 minutes
plus an ebike motor which weights the same as a gnat and has zero resistance when not being used
seems simple enough
So! You’re a bike component company designer with thousands to spend on R&D , looking for something to change on components to make existing components obsolete, what do you turn your attention to?
For me it would be the pedal to crank fixing, unchanged for donkey’s years, yet basically a bad design just good enough with steel cranks but which has led to thousands of broken Al. alloy cranks and grazed knees over the years.
They should have stopped messing with hollow cranks and outboard bearings.
