gaz said:anyway to work it out without a power meter?
plank said:Just wondering what other peoples power to weigh ratio is?
I'm 95kg mine is
6seconds
average 1325/95 = 13.95
1 min (actually 1min 5 secs for 1 km)
average 618/95 = 6.5
sorry become watt obsessed after having a go!
SimonC said:Power is usually measured over 1 hr for typical power/weight ratio calc!!
plank said:Do you think watt/kg only comes into play while going up hills? I can't see it having much effect on the flat or downhill....
edit also I think the regular gym bikes work from an equation of resistance and RPM so unlikely to be reliable.
Rob3rt said:Could be right, dont know, guess it depends on the equation used and the variables considered. I dont know how a normal power meter works, so cant say I know the difference between the possible ways a gym machine could potentially measure power and a power meters way. At a guess, a bike attached power meter works on some sort of equation too (again though I dont know how they work )
Bill Gates said:So how can knowing your sustainable power for one hour, 5 minutes or whatever time period help you with your training? It will always improve with training but then that's inevitable. If you are working to a training plan then unless you are peaking for a race, you will always be below what is achievable as you will be recovering from previous training.
Right now I'm way below peak fitness because of the bad weather. I don't need a power reading to tell me that, just as I don't need one to know when I'm at my best. It's a tool that pro's will use with their coaches because it's available and they can. What good it does a run of the mill club rider I don't know. I've seen those that recommend them can usually supply them as well (at a price).
Comparing your power readings is like comparing your average speeds. It produces a competition to see if you can beat the previous best. If you train like that you are an idiot.
The only reading that matters is your performance in a race. I.e Where you finish.
amaferanga said:I've just bought a power meter and haven't yet got round to doing any testing (I've had a stinking cold since the day before it arrived ) so I don't have any figures.
You might find this spreadsheet on Power profiling interesting.
