what is the difference between a 8mm and 10mm hex key?
Soup890
Crazy
leeds
I'm going to try and replace my bottom bracket for the first time but first I need to buy some tools. Any advice would be welcome I have a specialized sirrus sport 2014 if there is anything to watch out for please let me know?
Spinney
Bimbleur extraordinaire
Back up north
2 mm
(sorry, but someone had to say it!)
Panter
Just call me Chris...
Assuming it's a serious question, it does just refer to the width of the bolt. So a 10mm hex really is 2mm wider than an 8mm.
A local hardware store should have a selection of hex keys for a reasonable sum, I personally prefer those that either fold out of a tool (as long as its good quality) or come in a case so that they can all be returned to their rightful places when finished with otherwise I instantly lose them!
Do you not have a bike multi-tool type thing with hex keys on?
EDIT: Also have a search on Youtube, there are loads of really good tutorials out there for replacing/servicing BB's :smile:
subaqua
What’s the point
Leytonstone
yup just the size of the across flats on the hex.
there are a few workarounds and have been used succesfully on disassembling and reassembly of large water valves
ianrauk
Tattooed Beat Messiah
Rides Ti2
My hardtail requires a hex key to remove the cranks. (Hope BB, think it replaced a Shimano Hollowtech?)
But not an 8 or 10mm. They are far too big for the 2 crank bolts
PeteXXX
Hamtun
Size isn't important.. So I've been told.
If you have a set of them, just select the one you need.
jack smith
Durham
Heres a google image basically you tap the driveside through the bb and then tighten the non driveside with a 10mm allenkey i think all fsa cranks are like that
jack smith
Durham
Would help if i upload the image...
