rockyraccoon
I thought frame type would affect it. So here is more details (I might not need a new bottom bracket)..
I bought a new frame that came with a bottom bracket. I've transferred the whole groupset to the new frame but the BB. When I tried the crankset, the smallest ring touched the chain stay.
The manufacture states that a 118mm bottom bracket should be used with the crank I've got. However, the same crank has been used with a bb that seems to be shorter than 118 (If I am measuring it right) but longer than the one in the new frame. I have not removed them yet.
Would it be OK to use the crankset with bb that was used with the old frame since it worked fine before? Would the old BB work with the new frame (without smallest ring touching chain stay)?
