AndyRM
XOXO
 - North Shields
I presume to realise I’m talking about the opposite bead, not the bead you are trying to get over the lip!
Yep!
Yep, I'm not new to tyre changing, but this is just ridiculous!
You on sales commission. ?
Most of my tyres can be fitted by my patented tyre fitting device. Thing is we've all got them - thumbs !![]()
I was told very firmly at work that you never use tyre levers for fitting tyres. so I learned to use thumbs (most of the time).
So a combination of this, and talc have not worked. Am I missing something with the shoe? Because all that seems to be happening is that it unseats itself a bit further around?
I hesitate to suggest anything because I haven't done much with racing tyres, and I know how bl**dy frustrating this sort of situation is. The way I was taught twist the tyre and thoroughly deflated inner tube so the tube sits in the tyre, and not in the rim.
Hold the wheel so the unfitted side is uppermost with the top on a chair or something and the bottom resting on your belt buckle* and then work your way around pushing in with thumbs., twisting as you do so that inner sits properly.
At the top, unless you have the Thumb Of Thor you'll probably need to use both thumbs on one side, but if the tyre tries to escape in the other side, I find the twisting-to-seat-inner tube helps.
That said it takes practice and I've known two capable mechanics try the same method and have different results, so try it and ditch it if it doesn't work for you.
*Disclaimer: I don't know how essential the belt buckle is, I've never tried without it.
Recently had to change my tires (well, only one really, but I'd rather they matched).
Anyway, this has got me through 2 tyre levers now, bent spoons, destroyed my fingers but try as I might I just cannot get this last bit over the rim. They're GatorSkins, which I know have a bit of a rep for being tight, but I've never had any issues before.
Anyone got any advice? I've tried everything I can think of...
Nope, but it's a bit like watching folks put in a nail using a brick. Yeah, will work - but a suboptimal tool for sure.You on sales commission. ?
