Are you getting rid ? - angle grinder, hacksaw or dremmel. It will come off if you cut a slot into the crank arm where the square taper is.
I’ve had to remove one using this method, the bugger just wouldn’t shift
Too much power in your legsHad a weird issue yesterday pulling away from the lights big noise and the cranks just span, couldn't seen anything obvious changed gear and carried on, closer inspection today revealed this 🤦♂️
Luckily I could raid the Dawes for a wheel so stuck a 28mm tyre on it and ready for the commute tomorrow.
Will investigate a replacement sprocket over the weekend.
