Sittingduck
- Somewhere flat
Sounds like new tyre time…
Yes I was thinking the same, still plenty tread on it as well.Sounds like new tyre time…
Just bad luck then. how many miles they done?Yes I was thinking the same, still plenty tread on it as well.
I have no idea, the front is the original though, I have changed the rear once.Just bad luck then. how many miles they done?
I managed to keep the vast majority of the sealant in the tyre whilst removing and refitting and didn't make much mess which was a minor miracle, but topped it up a bit anyway. It seems to be holding air so far but time will tell
I didn't want to ride the shiny new frame until it had a few key areas protected but fortunately it hasn't dried out enough to take the best bike out recently anyway so I've not missed out on any miles
I ended up just doing four pieces of protection film; one on the chainstay, two on the rear of the seat tube and one under the downtube, just to protect the main stone/debris impact points. It'll pick up scratches over time but I may as well try and prevent the worst of it when it's still brand new
This evenings play showed the zero offset for the driveside crank is waaaayyyyyy out of the normal range - the calibration figure should be 890 +/-50 but it was reading 2502
I've lodged a ticket with Stages but for now I was able to unlink the two crank sensors and pair just the non-drive side so it'll still act as a single sided powermeter until I can get the other side sorted. Presumably at some point it'll have to come off and be sent away though putting the bike out of action. I'd had all sorts of problems with the Avio Powersense PM's and thought by moving to Stages I'd see some reliability but guess I was being overly optimistic again
Cleaned the rear brake pads and swapped the front pads out as they were pitted, glazed and had chunks of aluminium in them.
The blocks now have Koolstop Salmons, for better braking performance in the wet. Just in time for the sunny hot and dry spring I'm anticipating.
You should have done that in January, that would have put off all the storms in February.Cleaned the rear brake pads and swapped the front pads out as they were pitted, glazed and had chunks of aluminium in them.
