Did a quick repair this lunchtime with electrical tape and some plastic foam stuff I found.
Works a treat, very satisfying bodge.
Well I used some 6 micron paste followed by some half micron paste and it seems to have improved matters when it comes to reading number plates from video but there are still some deeper scratches left. The only way I'll get those out is to use 1200 grit emery paper to get below them and re-polish and it's not so easy to do that (the lens is set back a little from the surround so I'd have to grind through that too- it's possible to push the lens into the nap of the polishing pad but I can't do that with emery. It is handy having some almost unused metallographic sample preparation equipment at work)Did start polishing the lens but will need to take more time over it and use some coarser diamond paste to start with- didn't make much impression on the bigger scratches.
Is it actually a lens, ie, with curved surfaces or a flat window?Well I used some 6 micron paste followed by some half micron paste and it seems to have improved matters when it comes to reading number plates from video but there are still some deeper scratches left. The only way I'll get those out is to use 1200 grit emery paper to get below them and re-polish and it's not so easy to do that (the lens is set back a little from the surround so I'd have to grind through that too- it's possible to push the lens into the nap of the polishing pad but I can't do that with emery. It is handy having some almost unused metallographic sample preparation equipment at work)
Yesterday afternoon, the chain was removed, I also took the chain-rings off, to clean throughly, as was the front mech
A good dousing of 'red diesel' around the rear-derailleur, & left to drain/dry overnight
This morning, with a lot of road-muck washed out of the rear-mech, a new chain was fitted
I also pulled both sets of brake-pads to check for wear (discs also examined)
All seems fine now![]()
Don’t forget to put the FD and chain rings back on.
