A
frustrating morning of DIY failure, but over lunch I then got on with finishing the Forme road bike I collected from a contact of
@cyberknight last Monday.
- The single 50T and ground off 34T chainring were swapped with a different FSA 50/34 set, after a long soaking to get some seized/tight bolts off that my puny arms couldn't shift.
- Bar tape removed so the loose ends could be re-wrapped after removing the gel pads on each side which was causing them to loosen. Both sides re-wrapped fully.
- Front Tiagra 4600 derailleur fitted with new outer/inner cable. The hole to thread the gear cable through the frame was completely gunked up and it's taken several days of soaking and cleaning to get the gunk out.
- All adjusted and pedals on with a road test. All works although imo it could do with a chain link removing which we won't do if it's used as I'll swap the current 175mm 50/34 crankset to a 170mm 52/36 for son no. 2 or myself to use.
Plans? Not sure yet as when I collected the Forme my son was trying to fix his Boardman Airpro; whichever could be ready first was going to be used the next day for training. He got the Boardman done whilst I was in Derbyshire, giving me a bit more time rather than an overnight rush job.
However, having found out his BeOne can't be used in a UCI race in March (not an 'approved' frameset
) he'll have to use his Cervelo, with our turbo-sat NeilPryde Nazarê as a back-up. The Forme therefore
might end up on our smart turbo for a bit since one of the bikes is off to Belgium early.
