What Have You Fettled Today?
GeekDadZoid
Excuse the mess! Currently sorting a load of equipment for work and doing my bike repairs in my office so its got a bit messy.
Todays job was to finally fit the new calipers that @DCBassman kindly gave me at the same time as fitting the SKS Chromoplastic mudguards as pointed out by @figbat on the bargain thread. Brakes went on no bother, clearance for the mudguards was minimal, but I have got there. I was expecting the chainstay area to be the main issue but actually it was the front fork which caused me the most headaches.
Need to tweak the rear of of the rear one once I get it on the ground in the daylight and trim the brakes.
614556
614557
Fitted a new screen to an iPhone 6.
Won't be doing that again.
Chislenko
Today was a senior moment. Mrs.C wanted a bottle holder on her bike.
I had a spare in the garage, went in my bike spares draw and found two Allen bolts.
Put the bottle cage in place then spent ten minutes cursing why the bolts wouldn't screw in.
I was only trying to screw the bolts into existing Allen bolts that were already in the frame!!!!
Anyway she now has a bottle cage and as no-one was there to observe I haven't been carted off to an old people's home....yet!
gavroche
Getting old but not past it
North Wales
Whilst cleaning my Allez, I happened to check the wear and tear on the chain and realized it needs replacing so I ordered a new one from Chain reaction. It is coming next Thursday. £18.99 including delivery charge.
I did noticed last time I went out ( last Thursday) that gear changing wasn't very smooth so that could explain it. At present, I have a 11-30 cassette and will probably change it to a 11-32 when stocks are coming in again. Would it still run on 11-36 though?
Salad Dodger
Kent Coast
Put a new inner tube in the front of my MTB, so I could sell it as fully rideable. First to see it bought it at lunchtime, so now I can rearrange the contents of the garage as the bike is no longer taking up wall space.
Ming the Merciless
There is no mercy
Inside my skull
Fixed a leak around the hose (under hard braking) on my front hydraulic brake lever. The compression nut just needed loosening off, then retightening and all good. Then bled both front and rear brakes. First time in 23 months with no maintenance other than replacing pads. Not too much of a maintenance headache. Whole procedure took 30 mins followed by test ride. All good.
biggs682
Northamptonshire
Just fitted some new greentyres ie solid tyres to a friends wheelchair went on a lot easier than expected
GeekDadZoid
Brakes dialed in and ready to roll in the morning. Still not 100% happy on the rear guard but going to ride it first before I faff, I think I can get it a little closer.
614792
ColinJ
Puzzle game procrastinator!
I usually find that rough gear changing is due to friction in the cable, assuming that the gears are adjusted properly. Try taking the chain off and pull and release the cable by hand and watch the derailleur move in and out. It should move smoothly. If the cable is gunked up then you will probably be able to see that the derailleur moves in fits and starts. If that is the problem then you might get away with just cleaning and lubing the cable. If not, try replacing the loop of outer cable that goes to the derailleur.
As for the 11-36... If you set the chain length just long enough for a 30 then it will be a bit short for a 32 and a lot short for a 36! I always make my chain just long enough to cope with the biggest ring to biggest sprocket combination. Obviously by that definition, if you then made the biggest sprocket bigger, then the chain would be too short.
PS So leave some spare length in the new chain. It would be easier to shorten it later if you had to, than it would be to make it longer again! :okay:
Landsurfer
Fed up with the water in my instrument binnacle on the RE Himalayan ... Condensation is rife on these bikes.
This where my instruments spend lots of time ... stripped down on the radiator !!!
614806
Thursday morning, about 1100hrs, Ribblehead Viaduct in the North York Moors, bright sunshine, bloody freezing, waterlogged instruments...
614807
gavroche
North Wales
Thanks for all the advice. :okay:
At the moment, it is nearly impossible to buy a new cassette anywhere so that will be for a future purchase, if things ever get back to normal. :rolleyes:
Gunk
Oxford
any idea what’s causing it? I’ve never had that issue with any motorcycle modern or old
cyberknight
new chain on the commuter as after 3 months its at 100 % , very odd but it was "new " from the lbs that i have had issues with .
new bearings for the rear wheel on the ribble but i reckon the freehub needs replacing as the drive side cup is rough inside .
Took the mudgaurds off the boardman rebuild as i cant get on with the old sks ones as they are past it and rattle and rub so they need replacing even after i have bodged and screwed them to keep them working .
