LeetleGreyCells
Un rouleur infatigable
- Whitehaven Mansions
Came home to be told my wife's car had a flat tyre. Flat swapped for spare. My wife will take the flat to the garage tomorrow to be repaired (nail in the centre of the tread).
I'd be concerned if the wedge is as high as you say, you don't want that to slip.Today I replaced the stem on the Revell mixte. It's a vintage 1" threaded job, fitted until now with a low 80mm SR stem, which almost certainly was fitted with drops originally.
Now has a much taller post, with a 60mm riser stem. In fact it is too large an item really. At a reasonable height, it's as low as it will go, and the wedge is almost visible under the fork crown. But it has done what I wanted, and made the fit similar to the Scott.
Comparison
Shiny.
No idea when I'll get to ride it!
Not high. The new stem fills the entire steerer tube from top to bottom. It ain't going anywhere!I'd be concerned if the wedge is as high as you say, you don't want that to slip.
