Ming the Merciless
There is no mercy
- Inside my skull
Re did bar tape on left side of road bike.
Mine are perfectly aligned. However, when loading bike on car the other day, noticed the rear rotation direction was wrong. Only been like it 6 months. Observant, that's me...10/10 for manufacturer's name/valve alignment on the front wheel. 6/10 on the rear.![]()
I know! And it’s really irritating me. They were so difficult to get on the rims, I noticed it wasn’t quite lined up. It was so tight I was unable to slide it over 100mm and didn’t want to take it off again.10/10 for manufacturer's name/valve alignment on the front wheel. 6/10 on the rear.![]()
Cleaning and other bits today;
My Avanti Circa 1 winter commuter got a clean and cyclocross wheels on for a bit of use prior to the winter.
Then I had a look at the bike I'd bought a couple of weeks ago and gave three of the four away. I kept the Dawes Kingpin; it was a bit of a mess with not much working. The rear tyre and tube were in bits although the rear Sturmey Archer hub worked along with the shifter after some lubricant persuasion, so I did a temporary swap with a spare wheel.
Both handlebars grips were covered in some sort of ooze (old sun-tan lotion?) and a mess so they've been swapped with a spare pair. The seatpost was unstuck and cleaned - more
- and it'll need a new chain. The left brake cable is stuck, so that was cut off and a new one's being put together. Front wheel has had the bearings re-greased and a spare used front tyre.
I really don't need a 3rd Kingpin; I've a good one, a TT/racing project one, and wouldn't mind a folding version. But this one's spare for the moment: it'll head off to my storage unit once I get access again to it in a couple of weeks' time.
I hope you pulled those weeds up at the same time!
