I'd left my Bianchi hanging on the wall so long both tyres were flat and had popped off the rims
They'd been losing pressure slowly since I built them so I knew something wasn't quite right and decided to take the opportunity to strip them down and start again
First thing I noticed on both wheels was the tubeless tape was peeled up in a few places, and sealant had gotten to the spoke holes. That won't have helped then
I had bought a big roll of unbranded yellow tape some time back, seems this was false economy. Unfortunately it's also fitted in 2 other wheel sets so they'll probably get stripped at some point too if they start losing air
The next thing I noticed when cleaning the tyre up was there were nobbles of rubber all the way around both beads of both tyres, the larger of which had dry sealant around them. Seems pretty silly to have knobbly bits on a sealing surface to me so I went round with my side cutters and trimmed them all off
I had bought some Schwalbe high pressure rim tape to try this time; it states it's good to over 100psi with only one layer of tape applied which is higher than the tyres so I only wrapped it round once where I would normally do twice. It went on really nicely, sticking down well without too much effort so we'll see how well it stands up to use.
With that done I prepared to wrestle the tyres back on, but was fairly surprised to find I could mount and demount them (I put the first bead on backwards first, of course) then mount them again fairly easy by hand. Presumably this was due to the single layer of tape but I'm surprised that thickness of material makes such a big difference. I needed tyre levers to remove when I started with the old rim tape fitted
I popped some new sealant in before rolling the last of the bead over the rim then it inflated perfectly with no leaks first time
Seems to be seated nicely so I span it up a few times and will check it again in the morning to see how its holding
All being well I'll do the rear tomorrow - I've cleaned the tyre up and trimmed it's nobbles (ooh er!) but havent cleaned and taped the rim yet in case the tape was rubbish
