randynewmanscat
- Vienne, Poitou-Chrentes
Someones shed.
Pulled my MTB out of the shed where it has languished since before the first lockdown. Brakes were fscked completely, so new pads in both front and rear with the rear needing a full bleed as it was full of air. The pads were down to the backing plates so not entirely surprising.
Also pulled off the rear wheel pulled the axle to put some grease on the bearings as they were a little dry and straightened the hanger. All done in just over an hour, so pretty pleased with that.
Well the new battery came today. Managed to get it apart and separate the circuit boards etc, but failed miserably trying to put it all back. Some of the connectors are so tiny that it is difficult making a good connection, so I gave up and ordered a new garmin.
Bad luck, but at least you end up with a new device!
If you haven't killed it altogether, would you consider parting with it for not-very-much?
PM me your address and I'll pop it in the post. I had thrown it into the bin, so might need a bit of cleaning!
Today, I have mostly been reviving a dead Garmin Edge 200!
@Sharky was kind enough to do just that and didn't even charge me the postage.
Before:
I was a bit overconfident - it WAS really fiddly! I had 4 or 5 attempts to put it back together last night and got it working for 1 minute but when I reassembled the case the damn connector fell off again!
I had another go today and finally managed to get the power connector and screen cable inserted properly.
The next problem was that I didn't have a Torx driver to fit the tiny screws for the case. I gave up trying to use other types of screwdriver and hunted through my various piles of junk to find 4 small Philips style screws.
After:
Yay!
I have charged the battery up to 100% and am going to switch the device back on just before I go to bed so I can check the battery life. It is a new battery so I am hoping for 12 hours or so. That would be enough for most rides that I am likely to do. If I can get 9+ hours then a quick recharge at cafe stops would see me through a day.
Many thanks @Sharky!
I left the Garmin running overnight indoors and the battery lasted 13 hours. I didn't get a satellite lock so it wasn't exactly equivalent to running the GPS out on the bike. It might be that it used more power trying to get a lock, or perhaps it gave up and saved power?I have charged the battery up to 100% and am going to switch the device back on just before I go to bed so I can check the battery life. It is a new battery so I am hoping for 12 hours or so. That would be enough for most rides that I am likely to do. If I can get 9+ hours then a quick recharge at cafe stops would see me through a day.
Leave it recording on a window ledge - that'll give you a good idea.I left the Garmin running overnight indoors and the battery lasted 13 hours. I didn't get a satellite lock so it wasn't exactly equivalent to running the GPS out on the bike. It might be that it used more power trying to get a lock, or perhaps it gave up and saved power
If you mean indoors - that's what I did but it didn't get a satellite lock through the glass. My Edge 500 can in that position so I was a bit surprised. I'm thinking of putting it in a sealed plastic bag out in my back yard tonight.Leave it recording on a window ledge - that'll give you a good idea.
