derrick
- On the edge of London
Oh i did but no one with a camera, I will always be the first to try something new,I like that you didn't volunteer to be the test driver/rider yourself @derrick![]()
Blimey, you would have thought there would be obvious warning signs to rider long before it got so bad. If it is a cup & loose bearings type of hub I'd like to see the state of them after having been tightened to such a degree! Good luck with that oneWas asked to look at one of the collection of bikes I look after at work because the "front wheel won't tighten up" and keeps working loose despite being tightened with all their might.
Had a look and first noticed there was about 8mm of thread sticking out of the we nut where normally there is none visible..
Tried undoing the qr and found the plastic nut had broken off the steel inner nut and the spring was mutilated. Eventually got the nut off after much swearing and removing bits of spring from the thread. Qr skewer felt a bit bent but that isn't necessarily new.
Immediately noticed the hub seemed narrower than the fork drop outs and the little bits you'd expect to sit in the drop outs fitted between them.
Closer inspection shows that the nut side of the wheels Bearing dust cap was squished flat and has clearly been forced in against the hub body by the fork let/drop out. The wheel is locked solid. I suspect the whole hub and axle has been turning in the dropout I did think the rider had more mechanical sympathy, but apparently not.
I only had my cheap cone spanners and they didn't feel they'd budge it so God knows what's going on. Put a spare wheel into the bike for now and the defective one can go to the LBS for repair next week. I'm expecting a new axle and hub.
Blimey, you would have thought there would be obvious warning signs to rider long before it got so bad. If it is a cup & loose bearings type of hub I'd like to see the state of them after having been tightened to such a degree! Good luck with that one![]()
just fitted a brand x integrated headset as a replacement for the fsa acb one as the fsa ones are expensive and this was listed as a compatible replacement .The top part fitted perfectly but the bottom bearings did not fit into the frame , they seem to the eye to be the same size but to get in into the frame i would have had to hammer it in and then it would be stuck in permanently .It solved the issue of the rocking top part which was the issue im guessing the upper split ring was worn and not seating flushly .Annoying but not unhappy as the lower bearings are in good nick anyway.
i needed a complete headset somehow i misplaced a spacer/seal from the fsa one and you cant get a spare one ( i even contacted fsa )Just replaced my acb bearings with some from superstar. £9 for a 2pk.
https://www.superstarcomponents.com/en/shop/mountain/mountain-spares/mountain-spares-headset/
I didn't think they was obscenely priced and the originals lasted 6years 20k or so in all weathers.
CRC replied apparently the lower bearing is a different size and not compatiblei needed a complete headset somehow i misplaced a spacer/seal from the fsa one and you cant get a spare one ( i even contacted fsa )
