Ming the Merciless
There is no mercy
- Inside my skull
Oiled my recumbent chain, which took 3 hours
It's actually 4 x rear/4 x frontWhy three lights Richard?
It helps prevent my being knocked off, & having to return to work in a big yellow truck (Ambo), as it'd be far too embarrassing!!I leant against an open door there, you do like your lights!
Both mudflaps are from 'Raw', & are retro-reflectiveFor extra back up I stick a stripe of red retro-reflective tape up the centre of the mudguard on each bike and keep it clean![]()
Received the Ultegra stages crank arm so fitted it this evening, updated it to the latest firmware version and calibrated it ready for a test ride tomorrow
Whilst I was there I decided to trim the steerer down. I'd left it 10mm long when I built it in case it needed tweaking. With several hundred super comfy miles done I figured it was time to neaten the front end up 😊
I might shift one of the 5mm spacers above the stem at some point but will leave it as is for nowLooking forward to riding it tomorrow
A bit of redundancy, if the charge drops, so I have back-up
2 x https://www.halfords.com/cycling/bi.../bikehut-50-lumen-rear-bike-light-684507.html (wifes Boardman also has two of these, but BIGGER reflectors)
1 x https://www.halfords.com/cycling/bi.../bikehut-25-lumen-rear-bike-light-684440.html
1 x Smart? ( the uppermost)
2 x https://www.halfords.com/cycling/bi...argeable-front-bike-light---black-208302.html (as ''repeaters')
I was given this (courtesy of a friend/work collegue) & need to return it to Hope, to be repaired, which will replace the 'Smart white'. or the (Planet X) Magic-Shine
(R8)
And this, which I think(?) was on the towpath (access road to Birkwood Lock) on the Aire & Calder Navigation Canal, when my regular route was fully closed for water-main repairs
(circa 23:00)
I’ll bet you used to ride a motor scooter back in your mod days😀😀😀😀
