Nibor
Bewildered
- Accrington
If you mean SR Suntour XCM you may be able to wind up the preload to make them a little firmer, and if you know the exact model you may also be able to source a replacement harder spring.
Suntour may have improved this fork in the last couple of years but my experience is with a neighbours older MTB, the preload adjust made no noticeable difference and they were a very stiff fork. If @MonsterEnergy is a lightweight rider then he may be wanting softer suspension?If you mean SR Suntour XCM you may be able to wind up the preload to make them a little firmer, and if you know the exact model you may also be able to source a replacement harder spring.
so could i possibly get the sam 120mm travel but different make. e.g Rockshox. Would that make a difference?Suntour may have improved this fork in the last couple of years but my experience is with a neighbours older MTB, the preload adjust made no noticeable difference and they were a very stiff fork. If @MonsterEnergy is a lightweight rider then he may be wanting softer suspension?
As you say the OP may be able to get a different spring, I didn’t realise this was an option with this fork, you learn something new every day![]()
Is the fork you have too stiff or too soft, what don’t you like about it?so could i possibly get the sam 120mm travel but different make. e.g Rockshox. Would that make a difference?
its too stiffIs the fork you have too stiff or too soft, what don’t you like about it?
You could try what @Nibor suggests, a different spring?
You could get another fork but for complete adjustment to suit your riding and your body weight then you would need an air fork and they are not cheap.
what would i search? Sorry to be a painIs the fork you have too stiff or too soft, what don’t you like about it?
okay....thanks. I will probably save up for one...MaybeAir suspension fork
