First job was to fit the front rack. Being a Tubus
Tara Duo Lowrider, it needs bolting on the inside fork legs aswell as the outers. But the fingers wouldn't fit around the spokes. So the front wheel had to come out. Then I had to compress the rack a bit so the mounting holes lined up. Having fumbled and dropped the bolt numerous times which caused the spacers to roll under the side unit a couple times I got the thing fitted.
But there was a problem. The mudguard was warped at the front. Messing with the stays endlessly did no good. It's borked. So, the old cream guards came out and had to be fitted. Cue endless faffing about with nuts, bolts, dremelling holes and patching holes. But they're fitted.
Then the rear rack had to be fitted. As it's a non disc brake specific rack, numerous washers and spacers in the correct order need to be use and as with the front rack and mudguards, lots of clumsy bolt dropping and spacer/washer recovery front under the couch and side unit ensued.
Checked the panniers for fitting and all is well.
Much swearing and shouting did not happen. At all. Honest.
