Bad Machine
In the garage .....
- East Anglia
Repaired a hole in the ICE "Q" recumbent trike's seat frame.
When I bought it, the the previous owner's "recently-serviced" tadpole trike was missing the idler wheel on the chain run between the bottom bracket (at the front of the trike) and the drive wheel's cassette (at the rear).
For those unfamiliar, the idler wheel ensures an unfettered run for the the power side of the chain line as it changes direction half-way along the trike. I found the photo I took when I got it - the idler wheel should have been positioned under the central bolt on the photo - you can see the where the chain had worn through the chaintube further up and to the left.
I'd suggest that - judging by the damage done - the owner would have inititally thought nothing was wrong, then found the trike increasingly more noisy, and difficult to pedal. Thankfully, they can't have gone far before deciding to sell.
Hollow aluminium tubing, with no access on either side, so small strips of alumimium car body repair mesh were stuffed in, then set in place by drizzling quick-set epoxy metal into the hole. More epoxy metal added until hole completely full, then squashed to curve by wrapping with the non-sticky side of wide packing tape. Some wet and dry work and then primer and paint to finish.
