I don't know if it techically counts as a fettle but I gave my commuter a mechanical clean (wiped the frame but didn't give it a deep clean I don't want it to be too desirable).
But of course it counts, this is the most important fettle of all
If you've got a threaded BB it's the same.I need to tighten the BB cup-cone bearings on my work bike tonight. I had the replace the lock ring about 1 month ago and the replacement needs a minor adjustment.
That got me wondering. If I had a modern bike with something like a Hollowtech BB (which wore out) would be it possible to replace it with an old fashioned cup-and-cone or is the spec completely different?
But can you get hollowtech spindles to go with cup and cone? Wouldn't you have to go for square taper, which would require a new chainset?If you've got a threaded BB it's the same.
File the spindle down to fit.But can you get hollowtech spindles to go with cup and cone? Wouldn't you have to go for square taper, which would require a new chainset?
I assumed he meant worn out bb, but it could be the crank.File the spindle down to fit.
I'd assumed @overmind was talking of replacing a worn out crank with a different type.
In reply to the 2nd question I think not however I think it'll become more difficult to get high quality ones, much like the adjustable spindles are now of woeful quality compared to older ones.Yes, I meant worn out bb. That is a good point though. Of course the crank would not fit (Doh!)
The idea would be to put a square taper spindle in the BB with cup-and-cone bearings. But of course, I would need cranks/chainset that were square taper to fit this (I had not thought of that).
I suppose the question was. Would the shell of the BB that the hollowtech was fitted to have threads to fit a square taper fixed and adjustable cups. I think the answer probably depends on the bike.
A second related question would be. Do you think square taper BB's will disappear?
I am pretty sure that the theads in modern threaded shells are standard. As usual, a quick check with Sheldon should clarify any doubts.I suppose the question was. Would the shell of the BB that the hollowtech was fitted to have threads to fit a square taper fixed and adjustable cups. I think the answer probably depends on the bike.
