loopybike
You could always, ehem, commission some......Mine were Aluminium, wish I still had em now.
Not sure if I can like this. Don't want to be complicit in tempting the r*in f*iry.....Oh, forgot to mention. I removed the mudguards, will see how I get on without them through summer. Looks much better without though.
I made another bracket for my mudguard and fitted it this afternoon . I now have a pair !
This is what they look like fitted. View attachment 408139 View attachment 408143
This is where an "unlike" button is required after the weather this weekend.Well, it's forecast to rain on Thursday...![]()
An unexpected day off today so I took the bike out for a test ride. Within 15mins the bolts were loose so I popped to a lbs to borrow a 2.5mm hex. I rode another 30 miles and they started to come loose again. I reckon I'd get a race out of it but I came back and applied carbon grip and threadlock so hopefully I won't need to touch it again. My old bars were the same (2nm for a bolt isn't enough) and threadlock sorted them out.On the advice of a bike fit I hack sawed 1cm off the TT extensions. Vision had lacquered over the adjusting clamp to the ski poles so they took a bit of persuading. At least I figured that I could leave the relatively new cables in place through the centre of the poles and just hack saw carefully around it. When the fitter first said it I thought it was a re-cable job![]()
Things started off alright . The plan was to put the centre pull brakes back on the BSA TdF. The front pair went on and then the back pair, no problems. Removed the handle bars and stem to fit the cable stop and guide and removed the seat to do a similar thing. Now things started to play up. The brake blocks went in the front fine but the threaded cable stop end would not fit the bracket . The routing of the rear cable was a bit tight , but when I came to tighten up the cable clamp I discovered that the brake blocks were nowhere near the rim. The brake bridge was too high. It must have been made for 27 inch wheels .
I put the bike back in the garage for another day .
That's the spirit.I'm going back out to see what else I can mess up .
