Vantage
Carbon fibre... LMAO!!!
- Behind everyone else, Bolton
It was just inappropriate girl stuff....
Did it involve batteries, lube and fingers? Gotta be Di2 if it did.
A like for the idea of having a day off work to do some fettling, not for the bad weather!!!!!!Lubed the chain, went for a ride.
I really could do with a day off work and some bad weather as at least three of the bikes need a proper (full) clean & lube while a couple of others could do with a a good mickling of the chains.
Yeh, but if I have a day off and the weather's good, I go out for a ride instead of fettling.A like for the idea of having a day off work to do some fettling, not for the bad weather!!!!!!
Know what you mean, but is nicer to get the bikes out of the shed, spread out and fettle in the sunYeh, but if I have a day off and the weather's good, I go out for a ride instead of fettling.
 Prefer to fettle in the garage with the door shut. Far less chance of feline mischief.
.If I tried that, I'd end up with unwanted furry assistance.Prefer to fettle in the garage with the door shut. Far less chance of feline mischief.
Will be interested to see what the responses to this would be, as I would probably err on the extremely cautious side and not use it for fear of it being at a greater risk of failure. But then Caution is my middle name....Looks like I've got additional fettling to do - noticed a largish cut in my rear tire. It's not too deep so I bit the bullet and rode on it this morning with no problems but I'll be getting some glue to try and repair it... Never done it before but a quick google seemed to suggest shoe gloo is the stuff to use so I've just ordered some. I'll carry on riding on it until it arrives I guess, if it was on the front I'd probably think differentlyWhat are your thoughts peeps, ok to keep using it until I seal it up again? Should I be using something other than Shoe Gloo? It's a nearly new GP4000 if that makes any difference.
What is moot is how deep is too deep. If the cut has damaged the casing of the tyre, I'd replace at the very first opportunity. If its not cut right through I'd put a boot in and continue to ride temporarily until I got a replacement, but monitor.Looks like I've got additional fettling to do - noticed a largish cut in my rear tire. It's not too deep so I bit the bullet and rode on it this morning with no problems but I'll be getting some glue to try and repair it... Never done it before but a quick google seemed to suggest shoe gloo is the stuff to use so I've just ordered some. I'll carry on riding on it until it arrives I guess, if it was on the front I'd probably think differentlyWhat are your thoughts peeps, ok to keep using it until I seal it up again? Should I be using something other than Shoe Gloo? It's a nearly new GP4000 if that makes any difference.
Yep Kizzy always 'helps' whenever I do anything.If I tried that, I'd end up with unwanted furry assistance.Prefer to fettle in the garage with the door shut. Far less chance of feline mischief.
