Drago
- Suburban Poshshire
Fitted a new rear tube to Colin the Claus Butler.
I fitted a rear tube to my commuter bike also, mainly because I use tubes with Presta valves, and I somehow managed to snap the end of the valve while pumping up the previous tube.Fitted a new rear tube to Colin the Claus Butler.
Odd that it is so worn in just one spot. Even allowing for it being at the crank torque spot it is unusual for the big ring to wear so much and so unevenly.Was getting some slippage on the big ring today as I turned it over, so checked it out earlier. I think it's a bit worn. Most of the ring is ok, but I can see a bit of shark toothing at the bottom of this picture. Ordered a new one, but won't be here till Wednesday at the earliest, so will just have to put up with it.
Lucky Colin.Gave Colin a clean and lube, sprayed the steel fittings with Duck Oil.
