ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
YIKES!!!I have been doing more detective work to try and quieten the bike. I have reduced the ticking/clicking noises that it previously made but they still bug me somewhat. I notice an occasional rattle from the front of the bike which is proving equally hard to eliminate. I have tightened everything that I can think of, checked for flapping cables etc.
I went back and had another look for the source of the front-end rattle on the bike. I convinced myself that the headset must still be too loose. I went through the usual routine and it seemed fine. I applied the front brake and tried to rock the bike backwards and forwards with the wheel locked. Minor clunks ... Tightened the headset. Repeat. More minor clunks ... No way did the headset need to be tighter than that!
And then I noticed that the front brake was loose! I had previously checked that the bolt holding it on from the back of the fork was tight enough and it had seemed pretty solid. Closer inspection revealed that some light corrosion had stopped the bolt moving when I had tried to tighten it. I applied a bit more force and broke the thin layer of rust. The bolt was then clearly not tight enough, so I adjusted it and sorted the brake out.
I reapplied the brake and rocked the front-end; silence - d'oh!
I'll go back out there in a minute and redo the headset adjustment because I reckon it is too tight now. The forks still turn freely, but I have never tightened a headset that much before and I would rather use the minimum tightness necessary, rather than the maximum that I can get away with.
I'll ride the bike tomorrow and see how it feels and sounds!
