First time doing anything to the claud butler so decided to do a proper clean up of it...
Discs, derailleurs, Chain, Cassette and crankset removed and cleaned up in the parts cleaner.... all sparkly now
New gear cables, Grips, bottom bracket tyres and innertubes
Cleaned and polished up the forks, frame and wheelset
Taken it for a quick test ride around the block rides booooootiful
had a tinkering session last night on a 80's Peugeot road bike and stripped the headset and bottom bracket and then put it back together again with some fresh grease feels a lot smoother now
Set my Raleigh Technium up on the trainer today, got a proper old training tire put on, and had a go, after adjusting about every bolt one can find on an old Minoura Mag-Trainer.
A quick bleed of the front brake in my Cube and it's now back to normal rather than the lever going all the way back to the bar if I don't give it a few squeezes first
Full strip down and clean of the commuter. Which involved putting the new dynamo front light on, the new front wheel as it went past truable , which then led into resetting up the Magura hydraulic rim brakes and new brake blocks. Oh and a new front mudguard as I finally found the clicking noise ( broken stay bracket)
Only the frame forks and bars are the original now . Triggers broom bike !
Cleaned the Claud Butler.
Cleaned the Saracen, Tuned the gears, Put new brake pads onto it, Pumped up the tyres. Ready for my brother @redvision95 to pick up tommorrow.
Fitted my new handlebars (thanks @gavgav) and stem to the Raleigh.
New look for the New Year
Out of curiosity and because the weight of my bike has been commented on elsewhere, I did a bit of weighing and the new bits save 370 grammes. Not too bad.
