What Have You Fettled Today?
a quick 'tinker' before my ride down to the dr's & back. Seems my front brake block had been knocked whilst the bike was in the car over the last few days and this am was not allowing the front wheel to spin. It would not be persuaded to go back where it originally was or even budge at all, so it was kind of a 10 min dodge job because I had an appointment to get to. (Ideally I really need to take the calliper off and reseat it properly but I suspect it will be awkward and not want to come off and I don't have time to fix it properly before the weekend). slackened off the brakes until block that was causing the problem was close but not touching the rim anymore and then adjusted the other one using the allen key so it is now at its max adjustment and thankfully now my front wheel spins freely and my brakes work again.... will have to investigate more closely on Saturday (but bike has to operational again for Sunday) and suspect that corrosion is going to be a problem when it comes to dealing with this issue....
PeteXXX
Hamtun
Rear hub on the SL4 stripped and cleaned. New bearings fitted. Freehub stripped, cleaned and oiled. Test ride around the block. Sorted.
Now I'm offf to work a 12 hour shift.
decided to fettle the bike rather than the house that I am meant to be doing - much more interesting! :whistle:
so chain is off soaking in a pan of warm chainsaw oil and getting all the road crud off, bike's inside because it is pouring with rain and I need to touch up a rather large scratch on the paintwork... one that is going to take rather a lot of time to fix I think... (acquired last week brick wall verses bike when chaining it to some railings:cry:)
Much work needed... that's my thumb for size reference!
compo
Harlow
After my fight with the ditch and tree this morning I have ordered a new wheel. Just to check the forks for distortion I fitted my road bike wheel in the forks, after removing the disc calliper which fouled the spokes. It sits perfectly centrally and a very gentle ride down the street showed up no problems. There is no sign of physical damage to the head or anywhere else so it looks like I got away with only wrecking the wheel.
Biker Joe
I'm glad you're OK.
You shouldn't really be riding your bike up a tree or swimming in a ditch. I wouldn't bother trying either again.:whistle:
compo
Harlow
I'm giving up ditches, they only supply a certain amount of pleasure.
nickyboy
Norven Mankey
A tale of a Chinese toilet.
Here in a pretty decent hotel in Xi'an China. All has been ok re the plumbing so far. Without deliberately trying to be indelicate, just had a rather large dump.However, the flush mechanism seems to be faulty. So I was stuck with either ringing the front desk and getting some poor unfortunate to , ahem, deal with it or I had to deal with it myself.
Cistern wouldn't fill so the only option was to find something big enough to take plenty of water, fill it in the bath and then pour it down the toilet and hope for the best. Hotel rooms sadly don't come with buckets. However, they do come with waste paper bins. It looks watertight-ish so I went for it and stuck it under the bath tap. It worked fine. A couple of bin fulls down the loo and nobody would have been any the wiser.
cosmicbike
Perhaps This One.....
Egham
No bike fettling today, indoor cycling results in little wear and muck.
But I have painted the stair string this morning, now I only have to fit the ballestrading, defo post - Christmas
