What Have You Fettled Today?
Busy weekend. Finally off loaded my mates MTB after it's been in my garage 6 months after I serviced it for him. Managed to get a load of kids stuff out of my garage to a charity car boot. Sold a fair amount, but donated books/games and toy cars to the charity at the end, so that's cleared a load of room and now I can serivce my bikes with more room ! Just need to sell my daughters 18" BMX and a 6volt electric ride on trike now !
threebikesmcginty
threebikesmcginty
Corn Fed Hick...
...on the slake
I've gotta wash my bike, it's really filthy, my laziness still outweighs my guilt though.
Asa Post
Super Iconic Legend
Sheffield
New chainset fitted to the road bike. The middle ring was so worn that the chain wouldn't stay on when pedaling. Other rings not so bad, but bad enough to need replacing. New chain installed as well.
Due to difficulties getting the pedals off, and persuading the quicklink on the chain to join together properly, it took much longer than it should have.
my mother gave me a +50 pieces 3 dimensional glass jigsaw puzzle with no picture and some missing pieces... I finally have made this from it... (some of the missing pieces have been reconstructed using glass glue. Apparently it is now straighter than it was originally! I have asked my step-father to try a touch harder next time he breaks it because it only took me 5 days to glue all the pieces back together! :wacko:
Uranium Glass?
yes. Handmade in Denmark but the label has come off and I can't find the name of the manufacturer or anything even vaguely similar online - was thinking it would be easier to replace it. For some reason it has sentimental value (not known what because neither she nor my 2nd step father have been to Denmark together) and both of them were quite upset about it.
Dan B
Disengaged member
Last night I found a pair of cartridge-type brake blocks that I thought had been stolen along with the bike that I thought they were attached to when it was stolen, and this lunchtime fitted them (with new koolstop dual compound inserts) to the front brake of my commuter. Might have a fighting chance of stopping the bike when it's raining, now
lovely shine on the old blocks, too :-(
ShipHill
Worcestershire
I got fed up with the front deraillier on my Muddier Fox. I couldn't fathom out how to adjust the damn stupid thing. It wouldn't shift up to the big clanger and would go off the inside of the small clanger so I put the chain on middle clanger and took the whole gear change mechanism off. I now have a 6 speed which is plenty for my 1 and a bit mile lazy jaunt to the spaceship factory.
Gravity Aided
Land of Lincoln
Here's a nice site about "Vaseline Glass" as uranium glass is called here. Collectors quite mad about it.
http://www.vaselineglass.org/
compo
Harlow
I have just been to the postal office to collect a parcel which was a new bottom bracket, come home and fitted the new BB to the Trek and refitted the crankset. And it's only 0900. I will clean and refit the chain later, you can have too much of a good thing.
Original post in September, 2013. ^ This BB was a UN26 and it has failed after just 3 months, so today I have fitted a new UN55. Hopefully it will last a little longer. I can only assume the UN26 was faulty from new. These things happen occasionally and there is no point getting excited or worked up over £6.
ColinJ
Puzzle game procrastinator!
The rear tyre on my Basso had gone flat so that needed sorting. I took out the old tube and discovered that somebody in the past (not me) had repaired a puncture with a self-adhesive patch which had finally split. I peeled off the old patch and glued on a more permanent one but the tyre went down again overnight. When I checked again, I discovered that the new patch had not fully 'taken'. I put that tube to one side and replaced it with another pre-repaired one from my junk box. That stayed up overnight so I cleaned the cassette and the underside of my rear Crud Roadracer before putting the wheel back in.
I then cleaned the jockey wheels and Mickled the chain.
While I was at it, I adjusted the rear shifting because the rear mech had been slightly hesitant shifting to bigger sprockets.
Oh, and the front shifting to the big ring had been iffy for a few rides and it had been annoying me so I sorted that out while I was at it.
Everything seems to be working smoothly on the stand. The weather was foul today so I did not fancy a test ride. If there is a break in the showers tomorrow, I'll go out for a couple of hours and see how the bike performs now.
PS I decided to have a go at removing and replacing the tyre without using levers. I have had combinations of tyre and rim in the past that would have required me to have the finger strength of a large gorilla, but my current combination of Lithion tyres and Aksium rims turned out to be doable - hard, but not b***ard hard!
ColinJ
Follow up ...
I double-checked my bike while it was still up on the stand and noticed that there was a rumbling sound when I used the biggest sprocket. A half turn of the 'B-screw' fixed that.
The other thing that I had forgotten to do was to adjust the position of my Deda Dog Fang; follow my signature link (below post) for a description of what they do. I had changed my small chainring from a 30 tooth to a 26 and lowered the Fang to be alongside the top of the teeth of the new little ring. I found, however, that the chain was tending to fall onto the Fang and get stuck there rather than being deflected back onto the ring. I raised the Fang by about the height of the chain and adjusted its angle until the chain always dropped onto the little ring, no matter how clumsily I shifted down from the middle ring. I made sure that the chain never makes contact with the Fang in normal operation.
The bike seems much quieter and smoother in every gear combination now. I'm hoping that it works as well on the road as it does on the stand. I am a bit hard of hearing but on quiet roads I had sometimes noticed noises coming from the bike.
Manchester
THE BEST fettling ever! Attached a bit of old inner tube with some discreet cable ties on my rack where my Ortlieb bags connect and wow! A nice snug fit and absolutely zero rattle or sliding around! Also did the same for where the gear cables touch the head tube and now a sublime silent ride has finally been achieved. Loving it!
