You should know betterYes, the NDS bearing has been seen off by just 2 months of riding on wet, gritted roads without mudguards on the bike!
Sounds about right, I got about that with mudguards when commuting, so 200km per week through winter.The face of the DS bearing was pretty clean and dry and the bearing still feels smooth. The face of the NDS bearing was glistening with rusty-coloured water containing mucky grit, and the bearing feels awful when turning it with my finger.
Before you do that, its worth trying to ressurrect it, only takes a half hour or so including taking the cranks off. I used to do it in the kitchen at night when Mrs C had gone to bed!I will probably get the LBS to replace the bearing. I don't have the tools to do it myself and it probably isn't cost-effective (at my age!) to buy them. (I know that it is possible to knock them in and out, but it's a bit iffy.)
Remove the seal - lift it out with a sharp blade, so stanley knife or similar - one side of the seal will be slightly thinner usually, go in from that side, should lift out easily enough.
Flush it out with WD40 - use as much as you need and then when it's dry pack in as much lithium grease as you can force in and still get the seal back in. With a bit of luck it should run smoother. The grease you pack in will be more viscous than the original lubricant (probably oil based) so it will feel like there is quite a bit of friction if hand turning it, but when you get going the grease will warm up and loosen up a bit and you won't notice it on the bike.
If it still runs rough after that then get the LBS to replace it - but they may have difficulty getting smaller non-standard bearings so it could be worth sourcing your own first if you can. If it does work then you should get another month or two at least out of the bearing before either repeating the process or replacing.
