dimrub
Today was a day full of frustrations. With the Favorit, I discovered that the calipers I ordered do not seem a good fit. The front one's bolt is too short, so it can't be mounted properly - even if I forgo the front mudguard. As for the rear one, it interferes with the rear rack. I'm thinking of borrowing calipers from one of the other bikes I got for free - and figuring them out later (if at all). While at it, I'm thinking of maybe borrowing the rear hub from the Starkenburg. It's the same SA 3 speed (or a very similar one), and the rear wheel there will need to be rebuilt anyway, so why not - I can finish the Favorit this way, and equip the Starkenburg with a new one, when it finally arrives.
The GT DHi - I couldn't find a fitting front caliper adapter, but noticed the holes are aligned, so just bolted it to the fork (this is going to an exhibition, so why not). Managed to attach the rear derailleur (figuring out how to attach the hanger took a while) and the pedals, I'm now waiting for Alon to get me the tire and the stem to complete this. There are still some things to figure out, for example, I'm not sure I understand how the gear cable is routed. I think it's some kind of internal routing, but don't have photos with high enough resolution to be sure. Also, how the front brake cable is attached. On the photos I've seen it goes straight from the caliper to the lever, which is strange to me - surely it should be attached to the fork's lower at its high point?
The Turner - well, I haven't really done much with it, except attempting to connect the front derailleur and realizing the seat tube is too thick for it. How so? I thought front derailleurs should just mount, no problems, but apparently not.
The Brompton guy wasn't in, and tomorrow is an election day, so the movement in the sprockets is still there, and will wait till Wednesday. Perhaps I can fashion some kind of spacer myself, out of some spare headset rings I have around, because this dangling sprocket is annoying as hell.
