It's going to be clamped everywhere, believe me. Seeing the cabinet almost pitching off the slings turned my tripes to water....The ones where they clamp under load are better.
I've just come out of a technology demo centre where I spotted this -
Now that's a man toy!
The router is incredibly versatile without jigs... all it really needs is a fence to run against. Buy a guide bush for under a tenner, you can do so much more. It's by far the most used power tool i have... don't let the cost of commercial jigs put you off because you probably won't need them.When I looked at that earlier in the week I couldn't figure out how pins that far apart could possibly centre on the stock, but I totally get it now. Saves the complexity of needing an adjustment. The expense of commercial jigs before you can actually do much is what put me off a router, but that is really quite clever
[edit] ...you don't need a 'big' router either. Mine's a weeny 550w which for occasional DIY is perfect.
I find the books can be quite overwhelming and over-complicate things. Some of the jigs I've seen for cutting mortises are over engineered to the Nth degree, take ages to make, minutes to mount and are not at all versatile... mounting the pins directly into the base works perfectly for anything from an inch to four inch wide. ...and don't ask about the 'easy set' dovetail jig, there's nothing easy about it!Thanks - that's useful pragmatic info from a real person so to speak - rather than "routers are marvelous" or whatever from a router book. Already have some Festool guid rails for my saw so router would work with them.
That said, I can dados with the track saw quite easily, so still not quite sure if I'd get enough use from the router. Mm, maybe re-read my books a bit
Yep these are much easier to 'set'I find the books can be quite overwhelming and over-complicate things. Some of the jigs I've seen for cutting mortises are over engineered to the Nth degree, take ages to make, minutes to mount and are not at all versatile... mounting the pins directly into the base works perfectly for anything from an inch to four inch wide. ...and don't ask about the 'easy set' dovetail jig, there's nothing easy about it!
Can't see how the hard plastic of the card seals against the surfaces ... for £1.99 I'm sticking to this option (no pun intended).The corner of a credit card also works pretty well....
'kinell - how big a bolt does it need ? It's hardly a cinemascope Arriflex is it ?
