ColinJ said:My sister gave me some money for Christmas so I called in at Halfords to buy myself a track pump to leave in Coventry for use on my singlespeed bike. I spotted a Halfords-branded mini track pump and decided to buy that instead because I can take it out on rides with me. I tested it on the singlespeed bike and was pleased with it. It got my tyres up to a reasonable pressure without too much effort, and it is small enough to take in the Camelbak bag which I use on rides.
yenrod said:I got my bike - for myself
That's the one!rh100 said:I bought the same one I think with some christmas vouchers. Is it the Bikehut one? (£20) I managed to try out the fold out foot grip thing with it still attached to the card seemed sturdy enough and should do for the pannier bag for emergencies.
I used to use a Blackburn Airstik (original model) - it's a great little pump but I found it hard to use when tired because arm strength is required rather than just using body weight as you can with the Bikehut pump.rh100 said:I did have a mini CrankBrothers pump, but I found that because it's rigid it was difficult to put my back into it as kept pulling it off the valve. With the flexible tube connector of the track pump it should be a lot easier.
I have a really good Specialized track pump up here in Yorkshire but I don't want to cart that about with me!rh100 said:Have a cheap full size Lidl track pump at home for topping up.
Garz said:Tons of great stuff there jim!
ColinJ said:I have a really good Specialized track pump up here in Yorkshire but I don't want to cart that about with me!
Assuming you have Presta type valves - make sure that you unscrew the valve ends and then press them in to release some air before you start to pump the tyres up. The valves can often get stuck and need to be loosened before they will allow air into the tubes. On the other hand, you might just have a duff pump!rh100 said:Aargh!! I think I now need to upgrade - just been out to pump the tyres up for tomorrow and it looks like the Lidl pump has had it - only seems to be pumping on the last bit of the stroke - ah well - that will have to wait till my Birthday for replacement I think
ColinJ said:Assuming you have Presta type valves - make sure that you unscrew the valve ends and then press them in to release some air before you start to pump the tyres up. The valves can often get stuck and need to be loosened before they will allow air into the tubes. On the other hand, you might just have a duff pump!
